Associate/Full Member Social Ride 18th June, 2023
June's social ride is to Scotsdales, Market Street, Fordham Ely CB7 5LQ.
No need to book, just turn up and enjoy the ride. Open to all EAMG paid up members.
Note: If you have a friend interested in joining EAMG, then they can come along as a guest on the ride but let me know their details first.
peterbennetive
Re: Associate/Full Member Social Ride 18th June, 2023
Post by peterbennetive »
Lee and l are looking forward to it.
See you there.
peterbennetive
Any update on where we are going?
