June's social ride is to Scotsdales, Market Street, Fordham Ely CB7 5LQ.
No need to book, just turn up and enjoy the ride. Open to all EAMG paid up members.
Note: If you have a friend interested in joining EAMG, then they can come along as a guest on the ride but let me know their details first.
Distance: About 110 miles round trip - Approx.
Mick and Alan - please add mobiles to your contacts.
Associate/Full Member Social Ride 18th June, 2023
- peterbennetive
Re: Associate/Full Member Social Ride 18th June, 2023
Lee and l are looking forward to it.
See you there.
See you there.
- peterbennetive
Any update on where we are going?
