Associate/Full Member Social Ride 18th January, 2026
Hi all
Please join us for January's social ride - destination: Days Bakery, Newton. CB22 7PG.
Note: Please make sure your membership is up to date before joining the ride.
NOTE: CANCELLATION: If weather forecast conditions bad, then will advise of cancellation by 5pm Saturday based on the overall conditions in forecast - e.g. 5 degrees or below with chance of freezing. Note: we've experienced conditions below this temp in micro climates/areas sheltered by trees causing freezing patches ect.
Note: If you have a friend interested in joining EAMG, then they can come along as a guest on the ride as long as they let me know. Thanks.
Full tank of fuel - fuel available Sainsburys but no toilets. Toilets are at the BP garage Boreham interchange.
Distance: About 85 miles round trip - Approx.
Finish at MacD Regiment Way for coffee - about 14:00.
RUBBER - check TYRE pressures as advised in your manual. Check tread depth - law says 1mm (on wear tab) across 3/4 of the tyre width. Note: plan to change before this as the braking/grip levels reduce drastically as the tyre reaches the minimum legal requirement.
TRANSMISSION - engine oil also lubricates gearbox - in nearly all cases. CHECK YOUR CHAIN - IT MUST BE LUBRICATED AND ADJUSTED CORRECTLY.
Mick, Alan and Dave - please add mobiles to your contacts.
