Please join us for January's social ride - destination: Days Bakery, Newton. CB22 7PG.
NOTE: CANCELLATION: If weather forecast conditions bad, then will advise of cancellation by 5pm Saturday based on the overall conditions in forecast - e.g. 5 degrees or below with chance of freezing. Note: we've experienced conditions below this temp in micro climates/areas sheltered by trees causing freezing patches ect.
Distance: About 85 miles round trip - Approx.
Finish at MacD Regiment Way for coffee - about 14:00.
RUBBER - check TYRE pressures as advised in your manual. Check tread depth - law says 1mm (on wear tab) across 3/4 of the tyre width. Note: plan to change before this as the braking/grip levels reduce drastically as the tyre reaches the minimum legal requirement.
Associate/Full Member Social Ride 18th January, 2026
