Against high-velocity CPU pitching and repeated late-inning pressure, the Pete Alonso Program in MLB The Show 26 exposes a simple truth: forcing home runs lowers your plate-appearance uptime and slows the grind. The 300-homer milestone content is built around 10 objectives, but its real value comes from stacking progress instead of treating every mission as a separate chore. Players saving MLB 26 stubs for roster upgrades should view this program as a chance to test a power bat without reshaping an entire Diamond Dynasty squad. Alonso can produce fast results, yet only if his at-bats remain controlled when pitchers work the edges.
Moments Set the Timing Window
Clear the five Moments before loading into longer games. They provide early program points, but more importantly, they reveal how Alonso's swing behaves against different pitch locations. His value is not limited to pulling hanging fastballs; the useful read is how well his timing window holds up on inside heat, low breaking balls, and pitches just off the plate. These scenarios cover his rookie record, season production, Mets home-run history, Queens connection, and power identity. Treat them as a batting-practice lab rather than a speedrun. If you repeatedly miss underneath elevated pitches, adjust your PCI placement before chasing the larger Parallel XP targets.
Build One Lineup That Feeds Every Objective
The 2,000 PXP requirement from Mets and Orioles players should shape the roster from the first full game. Use several eligible cards, but do not fill every lineup slot with low-contact hitters merely because they qualify. A stalled inning costs more than it saves, especially in Play vs. CPU where extra innings are the engine behind efficient progression. Keep dependable bats around Alonso, ideally with speed near the top and extra-base-hit threats behind him. That construction improves offensive uptime: more runners reach base, Alonso sees more meaningful RBI situations, and Mets or Orioles cards keep earning PXP even when he is pitched around.
Alonso PXP Comes From More Than Power Swings
The 750 PXP mission for any Pete Alonso item rewards consistent use, not reckless inputs. Place him third, fourth, or fifth depending on the rest of the loadout, then let normal at-bats do their work. Singles, walks, doubles, runs scored, and defensive involvement all move the card forward through regular play. The same discipline matters for the 53 PXP from extra-base hits and 170 PXP from total bases. Those missions overlap naturally, so chasing them in separate sessions wastes opportunities. Look for a short burst window after a pitcher falls behind, but avoid selling out early in the count against cutters away or sinkers below the zone.
Use Controlled Modes for the Final Stretch
Play vs. CPU, Conquest, and Mini Seasons are the cleanest places to finish remaining totals because lineup control matters more than difficulty once the last few points are left. Ranked play can deliver faster competition, but it also reduces plate appearances when opponents refuse Alonso the pitch he wants. This program is ideal for players who enjoy building a themed roster and measuring a new slugger over multiple games. It is less comfortable for players seeking a short single-session reward, since Alonso's PXP target demands repeated use. If you decide to buy MLB 26 stubs, keep the spending focused on complementary hitters rather than replacing the free program path, because the strongest MLB The Show 26 strategy is still one lineup completing several goals at once.
