Please join us for November's social ride - destination: Franks Motorcycles, Moat Farm Business Centre, Turkey Cock Ln, Colchester CO3 8ND.
NOTE: CANCELLATION: If weather forecast conditions bad, then will advise of cancellation by 5pm Saturday based on the overall conditions in forecast - e.g. 5 degrees or below with chance of freezing. Note: we've experienced conditions below this temp in micro climates/areas sheltered by trees causing freezing patches ect.
Distance: About 75 miles round trip - Approx.
Associate/Full Member Social Ride 14th December, 2025
