Associate/Full Member Social Ride Sunday 23rd November, 2025
Please join us for November's social ride - destination Cafe Riverside, Omelette House, Ickelton, Saffron Walden. CB10 1SH.
NOTE: CANCELLATION: If weather forecast conditions bad, then will advise of cancellation by 5pm Saturday based on the overall conditions in forecast - e.g. 5 degrees or below with chance of freezing. Note: we've experienced conditions below this temp in micro climates/areas sheltered by trees causing freezing patches ect.
