*CANCELLED*Associate/Full Member Social Ride 18th May, 2025
APOLOGIES BUT I'M UNABLE TO LEAD THE RIDE THIS SUNDAY AND CANNOT GET A STAND IN. THIS WILL BE POTED ON FB AND THE GROUP EMAIL.
MICK.
Please join us for the May's social ride - destination TBA.
