Note: MEET TIME NOW 09:30 TO LEAVE AT 10:00 - The ride will go ahead Sunday but the route may change to main roads for safety and a different destination. See you there.
Mick
Please join us for February's social ride - destination is The Silver Ball Cafe, Reed, Royston, Hertfordshire. SG8 8BD.
The Silver Ball has been a Cafe since the 1920s, known for it's pin ball machines in it's day - still a Silver Ball hanging outside.
Distance: About 85 miles round trip - Approx. Note: I've planned the route on some great 'B' roads for safety.
Finish at MacD Regiment Way for coffee - about 14:00.
Associate/Full Member Social Ride 16th February, 2025
- peterbennetive
Re: Associate/Full Member Social Ride 16th February, 2025
How did Sundays ride out go? Did anyone turn up?
michelcouque
Ride went well with about a dozen taking part.
- peterbennetive
Nice turnout considering the weather
michelcouque
Even better all returned too
