*CANCELLED*Associate/Full Member Social Ride 19th January, 2025
*DUE TO THE PREDICTED FREEZING CONDITIONS THIS SUNDAY, WE REGRETFULLY CANCEL THE SOCIAL RIDE.*
Please join us for January's social ride - destination is The Silver Ball Cafe, Reed, Royston, Hertfordshire. SG8 8BD.
NOTE: CANCELLATION: If weather forecast conditions bad, then will advise of cancellation by 6pm Saturday based on the overall conditions in forecast - e.g. 5 degrees or below with chance of freezing. Note: we've experienced conditions below this temp in micro climates/areas sheltered by trees causing freezing patches.
Distance: About 105 miles round trip - Approx.
Das306
Re: Associate/Full Member Social Ride 19th January, 2025
Post by Das306 »
sounds good , hopefully it will walm up by then (Please !! ) last time I was at the Silver ball it was cash only :o , so make sure you have some reddys with you :D
Glen Brown
Post by Glen Brown »
Was at the Silver Ball early December. They have a card machine now. Enjoy the ride
