Associate/Full Member Social Ride 15th September 2024
Please join us for September's social ride to Stoneham Barns, Pettaugh, Stowmarket. IP14 6AT.
CANCELLATION: If weather conditions bad then will advise of cancellation by 6pm Saturday based on the overall conditions in forecast.
Mick, Alan and ~Dave - please add mobiles to your contacts.
Gil
Re: Associate/Full Member Social Ride 15th September 2024
Post by Gil »
Thanks Mick a very enjoyable day's ridding not quite sure what happened on the way back , but all adds to the fun 😂
