Tony Seaman is leading the ride this Sunday due to Alan and Dave not available. Thanks. Tony.
CANCELLATION: If weather conditions bad then will advise of cancellation by 6pm Saturday based on the overall conditions in forecast.
Mick, Alan and ~Dave - please add mobiles to your contacts.
Associate/Full Member Social Ride 4th August, 2024
