July's social ride destination is the back roads to Hearts Delight Garden Centre Cafe - Manningtree, CO11 2EF.
CANCELLATION: If weather conditions bad then will advise of cancellation by 6pm Saturday based on the overall conditions in forecast.
Mick, Alan and ~Dave - please add mobiles to your contacts.
Associate/Full Member Social Ride 14th July, 2024
