Associate/Full Member Social Ride 5th May, 2024
May's social ride destination is to THe Hungry Stag cafe.
Address: Junction 47a A14, Eastbound, Bury St Edmunds IP30 9FX
CANCELLATION: If weather conditions bad then will advise of cancellation by 6pm Saturday based on the overall conditions in forecast - e.g. 5 degrees or below. Note: we've experienced conditions below this temp in micro climates/areas sheltered by trees causing freezing patches.
Distance: About 115 miles round trip - Approx.
Mick, Alan and ~Dave - please add mobiles to your contacts.
Gil
Re: Associate/Full Member Social Ride 5th May, 2024
Post by Gil »
Thanks Mick and Alan for a very enjoyable day with great roads and company, even the weather played ball 😎
