Associate/Full Member Social Ride 14th April, 2024
April's social ride is to Waresley Park Garden Centre, Gamlingay Rd, Potton, Waresley, Sandy SG19 3DB.
CANCELLATION: If weather conditions bad then will advise of cancellation by 6pm Saturday based on the overall conditions in forecast - e.g. 5 degrees or below. Note: we've experienced conditions below this temp in micro climates/areas sheltered by trees causing freezing patches.
Distance: About 115 miles round trip - Approx.
Mick, Alan and ~Dave - please add mobiles to your contacts.
