Page 1 of 1
Associate/Full Member social ride Sunday 17th March
Posted: Thu Feb 29, 2024 5:27 pm
by Mick Hewitt
March social ride is to Oakington Garden Centre, Cambridge. CB24 3BD.
CANCELLATION: If weather conditions bad then will advise of cancellation by 6pm Saturday based on the overall conditions in forecast - e.g. 5 degrees or below. Note: we've experienced conditions below this temp in micro climates/areas sheltered by trees causing freezing patches.
Note: If you have a friend interested in joining EAMG, then they can come along as a guest on the ride as long as they confirm with me first. Thanks.
Distance: About 110 miles round trip - Approx.
Mick, Alan and ~Dave - please add mobiles to your contacts.
