Associate/Full Member social ride Sunday 17th March
March social ride is to Oakington Garden Centre, Cambridge. CB24 3BD.
CANCELLATION: If weather conditions bad then will advise of cancellation by 6pm Saturday based on the overall conditions in forecast - e.g. 5 degrees or below. Note: we've experienced conditions below this temp in micro climates/areas sheltered by trees causing freezing patches.
Mick, Alan and ~Dave - please add mobiles to your contacts.
