*Associate/Full Member Social Ride 5th November* 2023
November's social ride is to Roots & Shoots Garden Centre - Stowmarket Road, Badley, Ipswich IP6 8RR.
Cancellation: If weather conditions bad then will advise of cancellation by 6pm Saturday.
Note: If you have a friend interested in joining EAMG, then they can come along as a guest on the ride as long as they confirm with me first.
Distance: About 104 miles round trip - Approx.
Re: *Associate/Full Member Social Ride 5th November* 2023
