PLEASE NOTE; DESTINATION NOW HUNGRY STAGE CAFE BURY ST EDMUNDS - ROUGHAM CANCELLED AS NOW CONFIRMED NO TEA FACILITIES - NOT SURE IF MUSEUM RUNNUNG AS IT SHOULD?
May's social ride is to: Rougham Airfield Museum WW2 RAF station / USAAF Eighth Force and designated Station 468 (BU). The site was transferred to the Air Ministry in September 1946. The Control Tower, Bury Saint Edmunds IP32 7QB - I've been informed that the Museum/airfield is still open until the end of May. After that I think it's closing down for development!
Note: Small tea room sandwiches/cakes.
No need to book, just turn up and enjoy the ride. Open to all EAMG members.
NOTE: Colin Digby's Full Member is also starting from Sainsburys at the same time - I'll be at the back of the car park, Colin will be on the left hand side.
UPDATE**Associate/Full Member Social ride 21st May, 2022
