April's social ride is to the Waterfront Diner - Loraine Way, Bramford, Ipswich, IP8 4JS.
No need to book, just turn up and enjoy the ride. Open to all EAMG members.
Distance: About 105 miles round trip - Approx.
Associate/Full Member Social Ride 30th April
