Associate/Full Member Social Ride Sunday 5th March.
March's social ride will be to Scotsdale's Garden Cafe, Horningsea, Cambridge (CB25 9JG).
NOTE: If freezing conditions are forecast then I'll post by 6pm Saturday as to cancellation of ride.
No need to book, just turn up and enjoy the ride.
Distance: About 105 miles total.
