Associate/Member social ride Sunday 15th January
January's ride will be to Narey's Garden Centre Stowmarket. IP14 3QD. Lets hope the mild weather continues.....
NOTE: If freezing conditions are forecast then I'll post by 6pm Saturday as to cancellation of ride.
TEA stop at Acton - Wally's cafe.
Meet: Sainsbury's Springfield (CM2 5PA) - opens at 10am so no access to toilets.
Distance: About 110 miles total.
