Associate/Member Social ride 13th November.
November's social ride is to Hungry Stag cafe, Bury St. Edmunds.
Destination: Hungry Stag. IP30 9FX.
Distance: About 110 miles total.
peterbennetive
Re: Associate/Member Social ride 13th November.
Post by peterbennetive »
I'm away that weekend so you will have to change the date. 😆
steveAS
Post by steveAS »
I'll be there. See you the.
Gil
Post by Gil »
Very enjoyable ride out today with some excellent ridding by everyone given the misty conditions to start with. Thanks Mick for your time organising and leading and thank you backmarkers for being at the back !
Until next time thanks
DannyB
Post by DannyB »
Thank you Mick and Alan and all associated with todays ride, great routes and some technical lanes to add some fun. 😁👍
