AGT (Associate/Member Group Training) 9th October, 2022
Note:
Please register your attendance at AGT for Associates and FTFM (Further Training Full Members):
Can all those wishing to attend please email:
mickhewitt39@hotmail.com / or text 07762 889408 confirming name and attendance for the next AGT – if circumstances change after booking then just advise. No problem.
This will help to ensure Observers that attend have a trainee to take out. Very frustrating for Observers when no one turns up! They're very keen to help you.
Please book-in (see above).
