Note:
Please register your attendance at AGT for Associates and FTFM (Further Training Full Members):
Can all those wishing to attend please email:
mickhewitt39@hotmail.com / or text 07762 889408 confirming name and attendance for the next AGT – if circumstances change after booking then just advise. No problem.
This will help to ensure Observers that attend have a trainee to take out. Very frustrating for Observers when no one turns up! They're very keen to help you.
Please book-in (see above).
Please re-join for 2022.
AGT/FTFM (Associate Group Training) Sunday 11th September
Re: AGT/FTFM (Associate Group Training) Sunday 11th September
Morning, how long should I set aside for this, please?
phil reader
From 9 until 12 , 1 or 2 pm . If you have a time restraint let the Observer know.
Hope you enjoy the day.
