Alan will be leading August social ride as I'm on holiday.
Destination: TBA.
Distance: About 100 miles total.
Associate/Member Social Ride Sunday 21st August
Re: Associate/Member Social Ride Sunday 21st August
Thanks very much for organising a very good ride to walkers cafe today, very enjoyable and good to see some old faces and new members. Well done Alan now can I have that chocolate biscuit
thanks also to the back marker today well done
