Just a reminder that the AGT (Associate Group Training) for associates and Full Members(FTFM training) is on Sunday 10th July. We look forward to seeing you.
No need to book, just turn up on the day.
Please re-join for 2022.
AGT/FTFM Training Sunday 10th July / Members social ride
