April's social ride will be to the Waresley Garden Centre, (SG19 3DB).
PLEASE NOTE: IF WEATHER CONDITIONS BAD THEN THE RIDE WILL BE CANCELLED BY 6PM SATURDAY.
This is a relaxed ride keeping to the speed limits.
Note: Colin is also running the Full Member ride this day from Sainsbury. - my ride will park at the back of the car park, Colin will park on left hand side.
Destination: Waresley Garden Centre, (SG19 3DB)).
Distance: About 120 miles total.
Associate/Member Social ride 24th April 2022
