Associate/Member Social Ride 20th March, 2022
March's social ride will be to the Scotsdale Garden Centre, Fordham (CB7 5LQ)).
PLEASE NOTE: IF WEATHER CONDITIONS BAD THEN THE RIDE WILL BE CANCELLED BY 6PM SATURDAY.
This is a relaxed ride keeping to the speed limits.
Destination: Scotsdales Garden Centre, Fordham (CB7 5LQ).
Distance: About 110 miles total.
Finish at MacD Regiment Way for coffee - about 14:00.
Trevor Greenway
Re: Associate/Member Social Ride 20th March, 2022
Post by Trevor Greenway »
Just wanted to say thank you to Mick and Alan for a lovely ride out today, and for organising the great weather too ;)
peterbennetive
Post by peterbennetive »
Another good ride with some great people. Thanks Mick and Alan.
Yes, a good day had by all. Good to see you.
