AGT (Associate Group Training/FTFM) 6 th March 2022
Just a reminder that the AGT (Associate Group Training) for associates and Full Members(FTFM training) is on Sunday 6th March. We look forward to seeing you.
Note: Full members are welcome to come and participate in the RC talk then go for a ride - as pre-covid.
Guests are welcome if pre-arranged. Just let us know if you want to attend. Call Mick 07762 889408.
No need to book, just turn up on the day.
Please re-join EAMG for 2022 if not already done so.
PLEASE NOTE: IF WEATHER CONDITIONS UNSAFE TO RIDE THEN WILL BE CANCELLED BY 6PM SATURDAY.
