Page 1 of 1
*CANCELLED*Associate/Full Member Ride 20th February
Posted: Sun Feb 13, 2022 2:33 pm
by Mick Hewitt
February's social ride will be to the Scotsdale Garden Centre, Fordham (CB7 5LQ)).
*RIDE CANCELLED DUE TO WEATHER CONDITIONS AND POSSIBILITY OF FALLEN TREES ETC ON ROUTE*.
Destination: Scotsdales Garden Centre, Fordham (CB7 5LQ).
Distance: About 110 miles total.
Finish at MacD Regiment Way for coffee - about 14:00.
