February's social ride will be to the Scotsdale Garden Centre, Fordham (CB7 5LQ)).
*RIDE CANCELLED DUE TO WEATHER CONDITIONS AND POSSIBILITY OF FALLEN TREES ETC ON ROUTE*.
PLEASE NOTE: IF WEATHER CONDITIONS BAD THEN THE RIDE WILL BE CANCELLED BY 6PM SATURDAY.
This is a relaxed ride keeping to the speed limits.
Destination: Scotsdales Garden Centre, Fordham (CB7 5LQ).
Distance: About 110 miles total.
Finish at MacD Regiment Way for coffee - about 14:00.
*CANCELLED*Associate/Full Member Ride 20th February
