January's social ride will be to the Hungry Stag Cafe Bury St. Edmunds (IP30 9FX).
PLEASE NOTE: IF WEATHER CONDITIONS BAD THEN THE RIDE WILL BE CANCELLED BY 6PM SATURDAY.
This is a relaxed ride keeping to the speed limits.
Destination: Hungry Stag Cafe.
Distance: About 110 miles total.
Finish at MacD Regiment Way for coffee - about 14:00.
See you there.
Associate/Member Social ride 23rd January, 2022
- Kitchenman
Re: Associate/Member Social ride 23rd January, 2022
wimping out again
