August's social ride is to Scotsdales Garden Centre Fordham, Ely - CB7 5LQ.
No need to book, just turn up and enjoy the ride. Open to all EAMG paid up members.
Note: If you have a friend interested in joining EAMG, then they can come along as a guest on the ride as long as they confirm with me first.
Distance: About 110 miles round trip - Approx.
Mick and Alan - please add mobiles to your contacts.
Associate/Full Member Social Ride 20th August, 2023.
Re: Associate/Full Member Social Ride 20th August, 2023.
See you Sunday
Thank you very much Mick for a very enjoyable ride today, annd good route bar a bit it traffic in finchingfield .
Good to see so many bikes turn up and not a bad breakfast. Cheers to the back markers .
Hi mick and Alan,
Thanks for a great ride today and good weather and good to see all our friends ,all the best Doug Maz x x
- peterbennetive
Great ride today thanks guys. I have a member for 5 years and havenever seen such a large group of us out on a ride.
Great turnout for a great day out. Quite a few bikes and people out of shot, a very impressive turnout. Thanks to everyone for making it happen.
Unfortunately the photo files are too large to upload, but you all look great!
