Note: I'm unable to run this Sunday's social ride but Alan Burke will lead to La Hogue Garden Centre, Newmarket.
Please join us for December's Christmas social ride - destination TBA.
NOTE: CANCELLATION: If weather forecast conditions bad, then will advise of cancellation by 6pm Saturday based on the overall conditions in forecast - e.g. 5 degrees or below with chance of freezing. Note: we've experienced conditions below this temp in micro climates/areas sheltered by trees causing freezing patches.
Distance: About 105 miles round trip - Approx.
Associate/Full Member Social Ride Sunday 1st December, 2024
