Please join us for November's social ride - destination Waterfront Cafe, Bramford, Ipswich. IP8 4JS.
NOTE: CANCELLATION: If weather forecast conditions bad, then will advise of cancellation by 6pm Saturday based on the overall conditions in forecast - e.g. 5 degrees or below with chance of freezing. Note: we've experienced conditions below this temp in micro climates/areas sheltered by trees causing freezing patches.
Distance: About 104 miles round trip - Approx.
Associate/Full Member Social Ride 17th November, 2024
Chris_Gardiner
Re: Associate/Full Member Social Ride 23rd November, 2024
Sorry if I am asking a silly question but is this the "same" ride that Steve advertised as being on the 17th and is it correct that it is on Saturday? It looks like this is the first time in many years that I might be able to join you and I wouldn't wish to loose an opportunity to do so.
Chris G
Chris G
Re: Associate/Full Member Social Ride 17th November, 2024
Chris, just realised that I picked up 2025 calendar! This months ride is on Sunday 17th.
Sorry about that.
Mick
Sorry about that.
Mick
- peterbennetive
Lee and l are looking forward to join you. We won't finish at Mcd's as we will be flying away on holiday later in the night.
Thank you mick for a superb route today and thanks Alan for back marking in both directions a very enjoyable way to spend a Sunday in November cheers
Chris_Gardiner
My thanks to Mick and Alan for leading and tailing today's ride (and presumably also determining the route), very enjoyable. It was doubly enjoyable for me because this is the first time since well before Covid that I have been able to get out on a Sunday. I'm sorry I couldn't give my thanks personally but I was expecting to stop at MacDonald's on Essex Regiment Way and when this didn't happen it was better that I peel off and return to the other side of the river by the best route in order to visit Broomfield Hospital.
Chris
Chris
