Please join us for October's social ride - destination Dobbies Garden Centre, Rougham Road, Bury St. Edmunds. IP33 2RN.
NOTE: CANCELLATION: If weather forecast conditions bad, then will advise of cancellation by 6pm Saturday based on the overall conditions in forecast - e.g. 5 degrees or below with chance of freezing. Note: we've experienced conditions below this temp in micro climates/areas sheltered by trees causing freezing patches.
Note: Colin's Full Member ride is also starting at Sainsbury's same time. He'll be parked opposite the petrol station and I'll be at the back end of car park.
Distance: About 103 miles round trip - Approx.
Associate/Full Member Social Ride 20th October, 2024.
