Associate/Full Member Social Ride 23rd June
June's social ride destination is to Scotsdales Garden Centre, Fordham, Ely. CB75LH.
CANCELLATION: If weather conditions bad then will advise of cancellation by 6pm Saturday based on the overall conditions in forecast.
Distance: About 111 miles round trip - Approx.
Mick, Alan and ~Dave - please add mobiles to your contacts.
Spider
Re: Associate/Full Member Social Ride 23rd June
Post by Spider »
I will do 1st half then carry on to wells football club for the motorbike show if anyone want to join me let me know. Spider
Gil
Post by Gil »
Thanks Mick a very enjoyable ride, good route good company and great riding with a very tasty sausage roll .
Look forward to the next one cheers
