*CANCELLED*Associate/Full Member Social Ride 14th January, 2024
January's social ride is to Oakington Garden Centre, Cambridge. CB24 3BD.
*CANCELLED DUE TO FORECAST OF FREEZING CONDITIONS IN THE MORNING*
CANCELLATION: If weather conditions bad then will advise of cancellation by 6pm Saturday.
