DUE TO POOR WEATHER THE SOCIAL RIDE IS CANCELLED.
December social ride is to Tuddenham Nurseries, 3 high St, Tuddenham, Bury St. Edmunds. Ip28 6SQ.
Cancellation: If weather conditions bad then will advise of cancellation by 6pm Saturday.
Note: If you have a friend interested in joining EAMG, then they can come along as a guest on the ride as long as they confirm with me first.
Distance: About 104 miles round trip - Approx.
*CANCELLED*Associate/Full Member Social Ride 3rd December, 2023
