Associate/Full Member Social Ride 15th October, 2023
October's social ride destination is La Hogue - La Hogue Road, Chippenham, Ely CB7 5PZ . Alan Burke is leading the ride and Dave Crossley tail ending.
Cancellation: If weather conditions bad then will advise of cancellation by 6pm Saturday.
No need to book, just turn up and enjoy the ride. Open to all EAMG paid up members.
Note: If you have a friend interested in joining EAMG, then they can come along as a guest on the ride as long as they confirm with me first.
peterbennetive
Re: Associate/Full Member Social Ride 15th October, 2023
Post by peterbennetive »
SorryMick. Lee and l will be at Brands for the Bennetts BSB that weekend. Have a great time all.
Das306
Post by Das306 »
Hi , any word on where we are heading to on Sunday ?
Spider
Post by Spider »
The clue is in the ride details 😂
Doug merrygold
Post by Doug merrygold »
Hi Al,many thanks for a great ride out some of the roads have not been on before good route,and thanks to Dave for tail ending good to see a good turnout and all our friends again, all the best Doug Maz.
