September's social ride destination is to Waresley Park Garden Centre (Gamlingay Rd, Potton, Waresley, Sandy SG19 3DB).
Cancellation: If weather conditions bad then will advise of cancellation by 6pm Saturday.
No need to book, just turn up and enjoy the ride. Open to all EAMG paid up members.
Note: If you have a friend interested in joining EAMG, then they can come along as a guest on the ride as long as they confirm with me first.
Associate/Full Member Social Ride 17th September, 2023
- peterbennetive
Re: Associate/Full Member Social Ride 17th September, 2023
Any update on Sundays ride?
