Associate/Full Member Social Ride 16th July, 2023
July's social ride is to Bottisham Airfield Museum. Wilbraham rd, Bottisham, Cambridge. CB25 9BU.
https://www.bottishamairfieldmuseum.org.uk/about/
The Museum was opened in 2009 to commemorate the sometimes forgotten role of the airfield at Bottisham in World War Two. It is the only UK museum dedicated to the Royal Air Force, United States 8th Army Air Force and Belgian Air Forces. We are now operating out of the last remaining airfield buildings to exist within the airfield’s original perimeter.
The cafe sells hot and cold drinks, sandwiches, scones, cakes, crisps and snacks and ice creams.
No need to book, just turn up and enjoy the ride. Open to all EAMG paid up members.
Note: If you have a friend interested in joining EAMG, then they can come along as a guest on the ride as long as they confirm with me first.
