Page 1 of 1
Associate/Full Member social ride 19th February 2023
Posted: Thu Feb 02, 2023 7:07 pm
by Mick Hewitt
February's social ride will be to Simpsons Nurseries Fordham(CB7 5LW).
NOTE: If freezing conditions are forecast then I'll post by 6pm Saturday as to cancellation of ride.
No need to book, just turn up.
Distance: About 108 miles total.
