AGT(Associate Group Training)/FTFM Sunday 12th February
Posted: Mon Jan 16, 2023 9:44 am
NOTE: IF WEATHER FORECAST PREDICTED POOR CONDITIONS FOR SUNDAY, I'LL POST A CANCELLATION NOTICE BY 5PM SATURDAY LATEST.
AGT (Associate Group Training) / FTFM (Further Training Full Member) - to join FTFM please pay £20 to Membership secretary - BACS transfer with your name and postcode in 'reference' box. Could all Associate/Full Members please re-join EAMG. Thank you.
The AGT is held once a month, following the Tuesday Group night, for New Associates and Members further training (FTFM-Further Training Full Member) - held at:
Address: Beryl Platt Centre(formerly Longmeads House) , 12-14 Redwood Drive, Writtle, Chelmsford. CM1 3LY. Ride round the back to the left of the old building.
Time: Arrive 09:00 - Start: 09:30 - we have a good social chat before we start.
We typically have Q & A or Power point session on Roadcraft (Police training manual) lasting about 30 minutes. Members are then allocated to an Observer for the training - note: if you have time constraints then just advise the Observer. Your Observer will thoroughly brief you before going out. You will probably stop at certain times during the ride for a chat (usually tea break) and feedback. First time out usually is around 50 miles (2-3 hours) and finishes with a final de-brief on your ride and a ride report.
There's a charge of £10 for each participant towards payment for the venue etc. NO payment for the Observer for AGT training.
Note: If you would like to try us out as a guest, then you're welcome to come along for a try-out(no charge). Please contact me, as below, to introduce yourself and be booked-in.
When you join EAMG you will be allocated a dedicated Observer for your flexible 1 to 1 training rides. AGT's give you the opportunity to experience a different Observer for the day and meet with others socially in the group.
Please register your attendance at AGT for Associates and FTFM (Further Training Full Members):
Can all those wishing to attend please email:
mickhewitt39@hotmail.com / or text 07762 889408 confirming name and attendance for the next AGT – if circumstances change after booking then just advise. No problem.
This will help to ensure Observers that attend have a trainee to take out. Very frustrating for Observers when no one turns up! They're very keen to help you.
Thanks
Note: If you have any burning questions to use as a topic in our Q & A, then please advise me or bring along on the day.
'FULL MEMBERS' are members are welcome to come along to meet and go for a social ride after Roadcraft talk.
NOTE: Please ensure your motorcycle has a full tank of fuel, is fully legal for insurance, tax and MOT (if applicable) - no need to produce documents if you signed the disclaimer. And equally important that your machine has been POWER checked - pre-ride checks will be carried out by the Observer on the day. If any safety issues found then the observed ride could be cancelled.
RUBBER - check TYRE pressures as advised in your manual. Check tread depth - law says 1mm around the whole circumference and across 3/4 of tread pattern. Note: plan to change before this as the braking/grip levels reduce drastically as the tyre reaches the minimum legal requirement.
Note: If you've recently joined and not received your Roadcraft and Highway code, please let me know and I'll bring along. Or any questions?
Mick Hewitt 07762 889408 / mickhewitt39@hotmail.com
Look forward to seeing you.
The Training Team
Thanks
The Training Team
