December's social ride is to Scotsdales Garden Centre, Fordham, Ely. CB7 5LQ.
NOTE: If freezing conditions are forecast then I'll post by 6pm Saturday as to cancellation of ride.
Meet: Sainsbury's Springfield (CM2 5PA) - opens at 10am so no access to toiles.
Distance: About 110 miles total.
Associate/Member Social ride 4th December
Doug merrygold
Re: Associate/Member Social ride 4th December
Hi Mick&Alan thank for a great ride and lunch stop good to see a good turnout and Dave for tail ending,all have a great Christmas hope to see you in new year Doug Maz x x .
Doug/Maz, it was good to see you - enjoyed the lunch stop.
Mick
Mick
