Due to below freezing forecast for this Sunday we've decided to cancel the AGT. Let's hope 8th January AGT has better weather.
NOTE: IF WEATHER FORECAST PREDICTED FREEZING ON SUNDAY, WILL CANCEL AND UPDATE THIS NOTICE BY 5PM SATURDAY.
The AGT is held once a month, following the Tuesday Group night, for New Associates and Members further training (FTFM-Further Training Full Member) - held at:
Time: Arrive 09:00 - Start: 09:30 - we have a good social chat before we start.
We typically have Q & A or Powerpoint session on Roadcraft (Police training manual) lasting about 30 minutes. Members are then allocated to an Observer for the training - note: if you have time constraints then just advise the Observer. Your Observer will thoroughly brief you before going out. You will probably stop at certain times during the ride for a chat (usually tea break) and feedback. First time out usually is around 50 miles (2-3 hours) and finishes with a final de-brief on your ride and a ride report.
Note: If you would like to try us out as a guest, then you're welcome to come along for a try-out(no charge). Please contact me, as below, to introduce yourself and be booked-in.
When you join EAMG you will be allocated a dedicated Observer for your flexible 1 to 1 training rides. AGT's give you the opportunity to experience a different Observer for the day and meet with others socially in the group.
Please register your attendance at AGT for Associates and FTFM (Further Training Full Members):
Can all those wishing to attend please email:
mickhewitt39@hotmail.com / or text 07762 889408 confirming name and attendance for the next AGT – if circumstances change after booking then just advise. No problem.
This will help to ensure Observers that attend have a trainee to take out. Very frustrating for Observers when no one turns up! They're very keen to help you.
Note: If you have any burning questions to use as a topic in our Q & A, then please advise me.
RUBBER - check TYRE pressures as advised in your manual. Check tread depth - law says 1mm around the whole circumference and across 3/4 of tread pattern. Note: plan to change before this as the braking/grip levels reduce drastically as the tyre reaches the minimum legal requirement.
Mick Hewitt 07762 889408 / mickhewitt39@hotmail.com
Look forward to seeing you.
*CANCELLED* AGT(Associate Group Training) Sunday 11th December
