Page 1 of 1
Associate/Full Member Social Ride 24th July 2022
Posted: Thu Jul 07, 2022 6:23 pm
by Mick Hewitt
July's social ride will be to Roots and Shoots Garden centre near Stowmarket.
Destination: Roots and Shoots (IP6 8RR).
Distance: About 115 miles total.
Re: Associate/Full Member Social Ride 24th July 2022
Posted: Sun Jul 24, 2022 6:48 pm
by John Tipper
Hi Mick,
Many thanks for organising the Social Ride today. @ 30 degrees, it was quite hot but Roots and Shoots Garden Centre was excellent find, we'll be visiting them again. A great bunch of riders but shame about the massive tractor and slow hay cart that reduced the group's pace to a crawl.
John and Audrey
Posted: Sun Jul 24, 2022 7:23 pm
by Doug merrygold
Hi mick thanks for a great ride ad route good to see old and new faces and many thanks for Alan for back marking all the best Doug Maz.
Posted: Mon Jul 25, 2022 8:00 am
by Mick Hewitt
Yes, good day although some agricultural obstacles. Bit hot but enjoyed the company.
