AGT/FTFM Training Sunday 12th June, 2022
Just a reminder that the AGT (Associate Group Training) for associates and FTFM Members signed up (Further Training Full Member), is on Sunday 12th June. We look forward to seeing you.
All full members are welcome to come along to meet and go for a social ride after Roadcraft talk.
No need to book, just turn up on the day.
Please re-join for 2022.
