Page 1 of 1
Associate/Full Member Social Ride 22/05/22
Posted: Thu May 12, 2022 6:06 pm
by Mick Hewitt
May's social ride will be to the Scotsdales Garden Centre Fordham (CB7 5LQ).
Note: Colin is also running the Full Member ride this day from Sainsburys - my ride will park at the back of the car park, Colin will park on left hand side.
Destination: Scotsdales Garden Centre - we have been to this garden centre before which has good parking and large restaurant area. I have a really nice new route planned.
Distance: About 120 miles total.
Re: Associate/Full Member Social Ride 22/05/22
Posted: Sun May 22, 2022 8:41 pm
by Doug merrygold
Hi mick &Alan,
Thanks for a great ride and good company good to see new and old friends,the weather was great,many thanks again Doug Maz x x :
Posted: Mon May 23, 2022 2:12 pm
by Mick Hewitt
Hi Doug. Great to see you and Audrey and John yesterday. Always a pleasure seeing you all turning up. Hope you can make June.
Best Regards. Mick and Alan.
Posted: Mon May 23, 2022 10:04 pm
by Doug merrygold
Hi mick thanks for reply Maz enjoyed the day as well all being well see you on the next ride,Doug Maz .
